RE: Started my first kit build
BigMac,
It looks like you picked a great kit for a first build.. Nice flat-bottom wing makes things go pretty quick and straight. It will probably also fly a bit more docile for your 2nd/3rd plane..
I wanted to suggest the Peel-Ply method when it comes time to glass the center of your wing. I have tried several different techniques and did this the first time during my last build with a Global Skyraider kit.
Take a look Here: [link=http://www.rcuniverse.com/forum/m_7276786/mpage_3/key_/tm.htm]Global Skyraider Build[/link] on posts numbers 62 and 68.
This technique was very easy to learn and gave me a great smooth surface over the fiberglass. I have tried several techniques of thinning epoxy, layering Saran Wrap over the fiberglass and glue, even using masking tape to smooth down the finish... The Peel Ply technique worked GREAT.
Also, I had often fought with the folded fiberglass or nylon tape provided in the kit wanting to leave fold marks in the center. I did some experiments with ironing the material and reported it on the King Kobra Build, post # 68. It really helped keep things flat.. BTW, the Peel-Ply technique was used over the entire plane in this thread: [link=http://www.rcuniverse.com/forum/m_6496478/tm.htm]King Cobra Build[/link] I think Mikes use of Peel Ply starts on Post #49.
Just something to check into when you are getting ready for the next steps of building..
Keep up the great work.
