RCU Forums - View Single Post - Senior telemaster
Old 05-26-2011 | 04:03 AM
icarus98
Default RE: Senior telemaster
Thank you Gents,
I ordered the rubber bands that RCKen listed, so that should make it possible to fly this weekend as I had hoped. With the "bolt" on system for the wings I am looking at going in a slightly different direction.....I am going to experiment with a spring loaded bolt system, if you imagine the latch systems used on some H9 canopy's to secure them, but a much beefier setup. Two spring loaded bolts on both the front and aft sections of the wing.
I'll post a build with photo's once I get to that, I just need to locate the spring loaded bolts tough enough for the job....that is assuming the telemaster survives this weekend!!
Cheers!
