RE: CMP 120 Zero ARF Build thread
Do not fly at the cg set at 100mm that is way tail heavy. .........On the smaller zero you have my personal experience is that it should be set at 85mm, make sure your balancing it inverted with retract extended the through setting should be to manufacture spec
