RE: .60 size Pattern Tiporare Build
It's Friday and the wing panels are laminated. Just waiting for the epoxy to take set. Sometime tomorrow I will be able to start trimming off the excess planking and sanding flush. I started with a foam brush which started to come off of the handle and wound up using a piece of foam to finish off the spreading of the epoxy. I thinned the epoxy with 91 percent alcohol to be sure not to get it too thich which relates to more weight. After trimming and sanding the planking flush, I will weigh each panel and report the weight and add a picture.
Jim
