RCU Forums - View Single Post - .60 size Pattern Tiporare Build
Old 05-27-2011 | 12:33 PM
  #94
Jim Clausen's Avatar
Jim Clausen
Default RE: .60 size Pattern Tiporare Build
David,
I did thin it out a bit, but I applied it to both surfaces and it seemed to want to adhere well. It is under compression at the moment and will sit until at least 1300 hours tomorrow. The instructions said that it could be thinned with 91 alcohol, so that is what I did. Sure hope it was not a mistake at this point in the build. Tomorrow will tell the story for sure.
I am using three cinder blocks sitting on top of the shucks with both wings in the same stack. Later tomorrow I will post my results.
I finally ordered and 11 ounce Hayes tank and might have to modify my front motor mount in order to get it where I think I want it to go. Should have had the tank on hand before I installed the front mount. Live and learn.
Jim
