RCU Forums - View Single Post - Basic and Intermediate call sheets
Old 05-28-2011 | 06:20 PM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: Basic and Intermediate call sheets
Ah Heck, here is Basic through Intermediate. I did not create these and did not proof read them, there may be mistakes
Basic
Pilot Ready?
Judges Ready?
In the Box!
First maneuver,
Aileron Roll, next
Hammer Head, Pull into Vertical uplIne, Hammer Top, Establish vertical down line, Pull to upright exit. next
Reverse Teardrop, Pull to Forty-Five upline, Pull five-eights loop to a vertical downline, Pull to upright exit, next
Humpty Bump, Pull to vertical upline, Pull half loop over the top to vertical downline, center half roll, Pull to upright exit. next
Inside Loop, Pull inside loop back around to level. next
Sharks Tooth, Pull to a vertical upline, Pull back to an inverted forty-five center half roll to upright, Pull to upright exit. next
Half Reverse Cuban, Pull to a forty-five upline, center half roll to inverted, Pull five-eights loop around to an upright exit. next
Reverse Sharks Tooth, Pull to a forty-five upline, center half roll to inverted, Pull to a vertical downline, Pull to an upright exit. next
Immelmann, Pull a half inside loop with a half roll on exit, exiting upright. next
One and a Half Positive Spin, wait for the stall then one and a half spins see a the canopy establish a vertical downline, Pull to an upright exit.
End of Sequence!
Sportsman
Pilot Ready?
Judges Ready?
In The Box!
First Maneuver,
Goldfish, Pull to a forty-five upline, Center half roll, Pull three quarter loop around to a forty-five upline, center a two of a four point roll to inverted, Pull to an inverted exit. Next
Split Ess, From inverted pull half inside loop down with a full roll on exit. Next
Forty-Five Hammer Head, From upright pull forty-five upline, Pull to vertical upline, Hammer top, establish vertical downline, Center a full roll, Pull to upright exit. Next
Vertical Up Line,(carry it tall to set up for a spin) Pull to vertical upline, Center two of a four point roll, Push to an upright exit. Next
One Positive Spin, wait for the stall then one turn spin see the belly, establish a vertical downline, Pull to an upright exit. Next
Humpty Bump, (going outbound) Pull vertical upline, Center two of a eight point roll left, Pull half loop over the top to vertical downline, center a three quarter roll Left. Pull to an upright exit. Next
Half Reverse Cuban, Pull to a forty-five upline, Center a two of four point roll to inverted, Pull a five-eights inside loop with a half roll to inverted on exit. Next
Outside Inside Loop, From inverted, Push a outside loop with a half roll on top then pull around to an upright exit. Next
Immelmann, Full roll on entry then pull half inside loop with a half roll to upright on exit. Next
Down Reverse Shark, Push to forty-five downline, Center positive snap, Pull to a vertical upline, Push to a upright exit.
End of sequence.
Intermediate
Pilot Ready?
Judges Ready?
In the Box!
First Maneuver,
Sharks Tooth, Pull Vertical, Center Half roll, Pull to an Inverted Forty-Five, Center Negative Snap, Push to an Inverted Exit, Next
Hammer Head, Push to Vertical Upline, Center Two Half Rolls, Hammer, Establish Vertical Downline, Center Two of a Four Point Roll, Pull to an Upright Exit, Next
Reverse Teardrop, Pull to a Forty-Five, Center a Half Roll Opposite Full Roll, Push Five Eights Loop to a Vertical Downline, Center a Half Roll, Pull to an Upright Exit, Next
Immelmann, (finish high for a spin) Positive Snap on Entry, Pull Half Inside Loop with a Four of an Eight Point Roll on Exit, Next
One and Three Quarter Positive Spin/Opposite Half Roll,(exiting outbound) Wait for Stall Then Spin Right One and Three Quarters (see belly) Opposite Half Roll, Push to Exit Cross Box, Next
Cross Box Humpty Bump, Push to a Vertical Upline, Center Full Roll, Push Half Loop Over Top, Center a Three of a Four Point Roll Left, Pull to an Upright Exit, Next
Reverse Sharks Tooth, Pull to a Forty-Five , Center One Full Roll Opposite Half Roll, Pull to a Vertical Downline Center Positive Snap, Pull to an Upright Exit, Next
Inside/Outside Loop, Inside/outside Loop with a Half Roll on Top, Push around to an Inverted Exit, Next
Half Reverse Cuban with a Two of a Four Point Roll on Entry, From Inverted/Two of a Four Point Roll to Upright then Pull Five-Eights Inside Loop to an Inverted Forty-Five Center One and One Half Continuous Rolls to Upright, Pull to an Upright Exit, Next
Ninety Degree Turn with One Roll to the Inside
End of Sequence.
