RE: Curare 60
O.K. Dox-I read your e-mails and now I am using my thread for a resonse. Many of the items you mentioned re: wing prep. you gave to me when I was in the process of building the Big Kaos.....however, repeating for old ears is always welcomed! Those techniques worked very well. I was able to make some small hot wire tools for cutting the servo box cavity. Works like a charm....just not as neat as yours or R_G's....but worked they did. I also made a small circular one for the leads for the servo wires and in the Curare will also servo as a raceway for the retract lines. My next task is to make a fuse jig similiar to some that I have seen. I have a couple ideas for some modifications so it can be re-used on other fuses. We shall see how that comes out.
-Tim
