RCU Forums - View Single Post - Starter Current
Old 05-29-2011 | 08:29 AM
rgm762
Default RE: Starter Current
ORIGINAL: CGRetired
I hate to be so broad with the reply, but that's pretty much the best answer someone could come up without knowing more.
CGr.
yea there are just way too many factors to even begin to consider what amps "you" should be pulling, no two starter setups are identical, meaning my setup will read different amps as compared to yours as compared to the next one, amps measures the flow of electrictiy through all the wiring, the connections, and circuity including that in the starter. more resistance = more amps needed. what, if any problems are you having?
