RCU Forums - View Single Post - Phoenix 7 ARF Assembly Thread
Old 05-30-2011 | 05:04 PM
  #45
gade600sdi
Default RE: Phoenix 7 ARF Assembly Thread
Energyman, 1. did you put the Dubro tanks in with the rubber stopper on the bottom of the plane towards the landing gear or on top like a normal installation? 2. Did you drill new holes for the lines out the firewall and 3. did you use the remote needle valve assembly, or eliminate it and move the needle to the carb to simplify?
