RE: Aquacraft Super-Vee 27 Nitro.
Your engine is running lean. Its getting air in from somewhere; as you say it a new boat, it's probably something simple/obvious.... check/replace fuel lines; check your fuel tank for leaks; check/replace the o-ring for your carb.
