RCU Forums - View Single Post - Sig 1/3 scale Spacewalker
Old 05-31-2011 | 03:23 PM
  #163
huck1199's Avatar
huck1199
Default RE: Sig 1/3 scale Spacewalker
Started completion of the fuselage. Also the engine piston was polished and reassembled. I put some truse reinforcements in place; I used CA hinges cut with little tabs to tie the structure together. The top front of the fuse was built and sheeted. The center sheeting went on without a hitch. The left side was a pain; The wetted sheeting would not let the glue setup quickly. For the other side I edge glued the dry sheeting to the center with CA gel and then wet it with paper towels. When softened I the spead Titebond under the sheeting and taped it down. This method worked very well.
ID:	1617550   Click image for larger version
ID:	1617551   Click image for larger version
ID:	1617552   Click image for larger version
ID:	1617553   Click image for larger version
ID:	1617554   Click image for larger version
