E-Flite 60-120 Electrict Retracts, Problem
Problems with E-Flite electrict retracts.
Installed on Top Flite .60 P47 with Robart struts and 3" scale tires. Worked great to begin with but later began to drain the battery and I can only get about 5 cycles out of them before one stops short of the wheel well then less and less movement after that. Started with 4.8v and went to 6.0v as recommended by HH with no success. Anyone else had this problem? Called HH again and was told nothing could be done due to my modifying the intent of the retracts by attaching Robart struts. Don't understand that one. Never got the plane off the ground.
