RE: led light
Here are some photos of the product from Common Sense RC, just made these tonight.
Yes these are the three light sections as mentioned by Hulk1199 and between each section you can see the cut line in the close up. At every cut line there are four solder dots for doing any kind of wiring you may require.
The adhesive on the back is 3M brand so may be expected to work reasonalbly well.
