RCU Forums - View Single Post - eq10
Thread: eq10
Old 06-01-2011 | 12:11 PM
rrritchey
Default RE: eq10
Yes, back off your transmitter travel 10% from maximum. Reset the Eq10 channel. Get your mechanical linkage setup so that you get very close to your intended travel without using the Eq10 and max-10% of your transmitter travel. Only use the Eq10 to tweak your travel, not make major adjustments. You plane should be setup mechanically correct before you start doing electronic adjustments.
