RCU Forums - View Single Post - E85 might be E70 ???
Old 06-01-2011 | 06:36 PM
KeroPower
Default RE: E85 might be E70 ???
The ST 40 did run without the on board glow. At the very end I removed the current to the plug and it kept running. But there was a drop in RPM.
Yes it does keep running without current to the plug and it would have flown without the battery. I just used the battery to make it more reliable.
It must be the gasoline helping to keep the plug lit, because when I ran the ST on Sunny Side (which is almost all ethanol) and 20% castor, the engine died as soon as I disconnected the glow driver.</p>
