ORIGINAL: LGM Graphix
Hi Sean,
Aztek airbrushes are the Jet Joe's of the airbrush world, you can make them work, but by the time you're done *&$&(!($ around with them you don't want them anymore.
For what application are you talking about? I've been using Aztek for ages and for 1/48th scale models they work really good.
After all, that's what their meant for right?
I also used it to paint an Israeli camouflage on an 1/8th YA F-16, and it worked ok, but can end up costly in terms of nozzle replacements.....but again, that is not the intended use either. I would not use it again.
Assuming that we are talking about use for R/C.......no use in comparing to Jet Joe as it is clear the application for both is incorrect.
