RE: Try to hover question - drifting when light on skids
I am not familiar with that helicopter, but it is normal for a helicopter with tail rotor blades to drift left when taking off. The tail blades are used to counteract the torque of the main blades and keep the helicopter from spinning, and this in turn causes the helicopter to drift in the direction that the tail blades are pushing it.
Once the helicopter is in the air it will not drift as much since the tail blades are lower than the main blades, which causes it to tilt to the right a little. Keep in mind that when setting up the helicopter, the swash plate must be level, and the center of gravity as close as possible to the main shaft. If the set up is not correct it will never fly properly.
If it is nose heavy or tail heavy it will drift in that direction.
