RE: DLE-111 first start... warranty used, but things are looking good.
Basic inspection says all the carb stuff is impact, but it does bear closer inspection.
As far as the prop moving/being loose, that could be. I need to inspect the prop remenants around the hub, but I do remember seeing more marking on the prop than I expected. Just have to figure out whether they happened before or during prop failure.
-wpm
