RE: Adjusting the low speed?
Remember if you adjust the bottom it affects the top and vise versa. What you are looking for is the best balance between the two. Every adjustment with the lower screw make sure either the top has not changed or readjust it. If you start loosing performance you have gone too far. The top is more broad so unless you make sweeping needle changes the bottom is usually OK.
