RE: Super Sceptor
Bullard,
thanks for the info. Did your elevator pushrod split before the exhaust diverter went through the fuse or did you run the diverter and pushrod side by side? I've never quite figured out what the best approach for running exhaust down the bottom is with a pipe mounted on top and split elevators. Not a big fan of P-P elevator setups.
David.
