Lanier 232 Cap Arf
Mine on the kit was moving around also. If you looked you could see wear marks on the tube. I cut a small portion of the phenolic tube away in the fuse and then installed a hose clamp around it on the cut out. Allows you to loosen clamp to remove wing tube if you wish but stops the movement.
Randy
