RCU Forums - View Single Post - big lama spinning clock wise
Old 06-06-2011 | 04:03 AM
pgroom_68
Default RE: big lama spinning clock wise
ORIGINAL: bjethier
Just got big lama back together to test. Had lost throttle. I replaced 3 in 1 and reciever. Finally replaced transmitter. Got it to work and put back together. Seems like top rotor not turning anywhere as fast as bottom. If hit throttle hard will just spin around on the ground. Is the problem in the 3 and 1 adjustment maybe? Hope someone can help again. thanks
Hey again mate,
The same thing happened to me once - turns out that I had plugged the motors into the wrong sockets on 3in1 and twisted them to reverse polarity. It seems to be an easy thing to do......and very confusing.......but easy fixed - just unplug/replug them into the other sockets and twist the plugs so the rotors spin the correct directions. Bottom rotor clockwise - top rotor anti-clockwise (when "sitting" in the cockpit)
Hope this solves the prob
Peter[sm=shades_smile.gif]
