RE: Quick battery question
I personally use dual Fromeco Li-Ions now, but used Nicads up until I switched for weight requirements. As Joe said, if it's not broken, don't try to fix it. Use the batteries that meet YOUR needs, that YOU are comfortable with and what has worked for YOU!! There is absolutely nothing wrong with the batts. you are using.
