RCU Forums - View Single Post - Curare 60
Thread: Curare 60
Old 06-06-2011 | 09:03 AM
doxilia's Avatar
doxilia
Default RE: Curare 60
Tim,
nicely done fuse jig! I hope that with the PDF wing plan printed at Kinkos, things now make more sense.
I see that you've got your nose gear nicely installed in the FW. Before you frame up the fuse, I'd recommend that you also install your engine mount - it will be much easier to do it with a free FW. The mount bearers might just need to be a tad off centerline to allow for the right thrust of the engine. Like wise for the downthrust - a tad up from thrust line.
Please post some pics of the wing and plan when you've got it cut.
David.
