RE: .60 size Pattern Tiporare Build
The wings are now rough fitted to the fuselage, meaning that they are centered side to side and perpendicular to the rear of the fuselage. I have only marked the side of the wing with an ink pen for reference so that when I am ready I can get close to the correct position easier. I need to recheck the angle of incidence a couple of more times to get some confidence that what I have done is in fact where it should be. Can't be too cautious here.
The center section is glassed and sitting on the bench waiting to cure.
The ailerons are hinged and are put aside for later installation. I have not however put in the 4-40 threaded hole in the dowel for the aieleron horn. That will come later.
Kinda done for the day.
David,
Each and all of your comments are appreciated. I consider each comment positive. Keep them comming.
Jim
