RCU Forums - View Single Post - would a carbon fiber rod be strong enough to hinge a removable rudder?
Old 06-06-2011 | 09:22 PM
VerneK
Default RE: would a carbon fiber rod be strong enough to hinge a removable rudder?
A carbon rod would be plenty strong to hinge a rudder. However, I'd be concerned about the rod wearing down by the friction of the hinges, dirt, etc, rather than the hinges being worn by the rod. A lot of that depends on what the hinges are made from. If they're nylon, I don't think you'd have any problems. If they're phenolic, as in the Integral, there could be a problem but I wouldn't expect an instant catastrophic failure. The wear would be gradual, if at all, and something you could easily spot if you inspect it on a regular basis.
Verne Koester
ORIGINAL: rcflyer4fun
I am finishing up a new pattern plane and I'm a few onces over weight. Do you guys think a carbon rod instead of a piece of music wire would be strong enough to hinge together a removable rudder?
Should I be worried about the carbon fiber wearing into the hinges?
