RCU Forums - View Single Post - MVVS Twins
Thread: MVVS Twins
Old 06-07-2011 | 07:46 AM
fujiman
My Feedback: (133)
Default RE: MVVS Twins
fiery, could you possibly post some pics. of the fuel diverter that you and jim c. came up with. as posted i too have 1 of these twins, a 1.20cid. thot about a walbro wt-499 alky carb. because of the opened up jetting. the walbro carb. that came with the eng. just is lacking in fuel flow. thought about fabing up a new 90 degree(carb. facing forward) manifold set up with a little greater volume with the reed setup just under the carb. and then putting in a triangle diverter plate down into crank case to direct fuel mix towards both cyls. kind of like a cars manifold does. anyway just a thot.
