RCU Forums - View Single Post - Pull Pull on elevators?
Old 08-15-2003 | 12:46 PM
Crash90
My Feedback: (17)
Default Pull Pull on elevators?
When setting up the pull pull for the elev. is there anything I need to know? For example. Does the servo need to be mounted in the center of the fuse? Does it have to be mounted at the same height ad the stab?
It will be going into a 1/3 sukhoi which calls for a minimum of 80oz torque minimum per elev. I have 3 options.
1 Install 1 jumbo servo capable of handling the load.
2 I can install 2 servos connected together in the middle of the fuse
3 I can install 1 servo on each side of the fuse.
I think this is the best option as it will offer some redundancy.
