RE: Comp ARF BAe Hawk Build Thread
Ian,
I drilled a small hole vertical into the carbon tube and put a 2mm c/s bolt in. Totally hidden by tailplane but easy to remove! My fin is tight when front bolt is in so not adding anything else. How do you fit the scale cockpit when the steering servo comes up into the space needed?? Pics would help.
Ian.
