RE: Phoenix 3.0 an DX5e..........
What do you mean, a view from the plane? As in a "cockpit view" on the ground?
You won't get that from your radio. You would need to install a real-time camera with some sort of transmitter on the plane, then a receiver and some sort of display on the ground. It's been done before, but by someone that is much more advanced than I am.
If electric, this will involve some weight and will require recalculating the power for that plane. If glow, well, depending on the setup, you may not need to re-power the plane.
CGr.
