RCU Forums - View Single Post - Phoenix 7 ARF Assembly Thread
Old 06-09-2011 | 05:30 AM
  #50
hook57
My Feedback: (21)
Default RE: Phoenix 7 ARF Assembly Thread
KLX,
Have you trial fit or set the wing in the saddle yet to check wing / stab alignment? Curious because mine was off quite a bit. I had to build the saddle up about 1/16 or so with epoxy/micro to get it aligned with the stab. Also, wing bolt holes were off enough that one aileron nearly touched the side of the fuse, had to open aft two bolt holes to square it all up.Some were thinking they'd try heating then twisting the aft fuse to straighten it. I would think the vertical stab would be off then, at least mine would have been.
hook
And the blue trim on the stab has started to come off *&^%(!
