RCU Forums - View Single Post - Conversion to DBC2
Old 06-09-2011 | 07:49 AM
dash69
Default Conversion to DBC2
Hello All,
I aquired a metal hull Stug 3 and because of not being careful the power switch ( on a length of wire) was able to short out the receiver board. Thanks to Phil I have a wiring diagram that shows the connections to a RX 18 board. Transmitter is a Spectrum 5 .
My question is the DBC2 came from a worn out Pershing. WHen the DBC2 is installed does it retain the settings on the card from teh Persing? Will it function as a Pershing as far as momentum is concerned? I found the 2.4 radio to be outstanding in means of control of the Pershing and I wish it for the Stug.. Next will be my KV-1 still not finished, Elmod or SLU...have not decided yet.
One more please when the trim for left or right steering is to the max, Does this indicate an electrical issue or Mechanical?
Thanks for any input on this.
Be well,
David
