RE: Delayed Full Throttle
It is a time delay, if you advance the throttle to full it advances normally for the first half of the stick or so then the RPM remains constant at ~50% then suddenly surges to wherever the stick is located (usually full by that time.) It is most noticeable on a takeoff run and I have not done much testing to determine how repeatable it is. it happened on two of three takeoff runs the last time we were at the field.
