RE: *SD-10G Keep Losing Expo*
If you change the layout (ie delta/2/4 ailerons etc) you will lose all expo and rate information for that model!Iknow done that the other day. I have not seen the problem that you are esxperiencing but just want to be sure you have not changed that area after programming expo etc.
