RCU Forums - View Single Post - Complete new CDI - website open
Old 06-09-2011 | 12:42 PM
  #494
wildman90
Default RE: Complete new CDI - website open
john,
the ignitor coil has not produced a spark yet. i may have the primary hooked up wrong.
will the 3000 rpm tester work on both boards you sent? when i test for voltage to the coil with a cheap VOM, i only get 200 to 300 volts. i am assuming that is because the meter cannot react fast enough to catch the peak voltage. i dont want to fry my good meter. i use the harbor freight cheapies for most things.
is the board with the timing circuit, the one on gompys site?
