RCU Forums - View Single Post - Curare 60
Thread: Curare 60
Old 06-09-2011 | 02:55 PM
  #31
mmiller1
My Feedback: (75)
Default RE: Curare 60
Pattern Guys-David, Ralph,Chino: I just installed my engine mount. Due to the fact that I have only 2 1/4" from inside at the firewall, I had to use what I think is a 40 size Sig mount. I think it will be fine, however. The vertical and horizontal beams measure 3/8", which is the same as the 60 size. This is the type of mount that has the triangular bracing connecting vert. and hor. beams. I added the engine and I see that most of the side of the fuse in that area will have to be removed in order to install and uninstall the engine.
There will be a top block and a bottom block with a nose ring as well to give form to the nose. I was just wondering if any of you gents could pass on a pic of what that finished area might look like. It could be your UFO, Tipo or Curare because I am sure the basic shape will be similiar. I have to find a friend with a band saw so I can cut those blocks that I glued up. Then a ton of sanding and shaping. With the 2 degrees of down and 3 degrees of right, do you think this bird should track with little rudder input?
Tim
