ORIGINAL: i7x58
Ok guys, based on PM that I got from Atam, he made a CDi from a French site and is for a Suzuki engine, says that it has 3 tables of advance curves and has real hard time to optimize it. Now with Ignition control soft from here will be ideal for him to try to find the best curve by creating his own.He made the timing board ( but I do not know if is the old or new timing board, did not mentioned that) and has trouble comunicating with the programer to get it in program mode. Says that is geting in program mode if he shorts the TX-RX on the PIC, if he works the SW from the CDI schematic does not work. He is asking if is a HEX issue.
This is all I got so far, I do not know much about this and I can not assist...all I can do....translate.
Adrian
Hi Adrian,
Where did you go am waiting for something from you.
Was able to get more of the three wire coils.Am healing fairly well from last surgery .Have titanium holding my ribs and sternum togeather.
Been flying a lot can hand crank gas engines now.Was cleared to lift over eight pounds.
I am still closed and will remain so. Still doing a little UAV work with high output CDI.
Hope all is OK with you.
BCCHI(AMA 2500).
