RE: orbit power jack and hitec servos
hello chad as i understood the orbit dose amplify the servo signal from what a regular 2.4 receiver puts out,it states in the instuctions that it is a 14 channel servoamplifier with double voltage regulators for the 6014 receiver enabling you to gang a few servos onto one channel is this not correct,,says the max amplifiers of the power jack6014 buffers the servo signals to 5 volt level,i have checked both regulators under a load and and they are a consistent 6.1 volts and according to hitecs response that voltage is not a problem,,not bashing the power jack i would really like it to work may all be just a coincident that this is the first burned servos and the first powerjack will put more ner servos in and bypass the orbit and see what happens thanks for the input
