RCU Forums - View Single Post - Thunder Tiger 91 Problems ....
Old 06-09-2011 | 11:01 PM
mike109's Avatar
mike109
Default RE: Thunder Tiger 91 Problems ....
G'day
I had the same engine mounted in a similar way. Mine used to dead stick. What it needed was quite a lot of running in and then it was fine.
Suggest you pull it out of the model, put it in a test stand and run it for at least half an hour in short runs then try again.
The prop throwing suggests a lean mixture when you are starting it.
Mike in Oz
