ORIGINAL: Jonde
Dano
Sorry, use 1N4007 diodes. When I looked at the diagram I uploaded I realized that I made a mistake and called them 1N3007 diodes. Hay, it's late, what do expect from an old guy...
This is a first for me?? Some of my electronic ignitions do state you should only run 4.8 volt Nicad but Nim work just fine for me. As far as the flight pack of a plane goes even the charged voltage of the A123 doesn't have any effect on the RX, the servos are what doesn't like the added voltage. Now they are making high voltage servos for those that like to feed them the higher juice.
The diodes look like a cool idea but isn't that just a do it yourself voltage regulator??? If so I like the idea as a money saver plus I like making my own gear.
