RCU Forums - View Single Post - Sig 1/3 scale Spacewalker
Old 06-10-2011 | 12:38 PM
  #182
huck1199's Avatar
huck1199
Default RE: Sig 1/3 scale Spacewalker
Made some more progress.
1. Decided to make the balsa block in front of the wing removeable. So I reinforced the wing hold down straps and put a tongue on the balsa block.
2. Installed all the stringers that give the fuselage it's rounder shape. I mitered the joint of the side stringers where the fuse angles to a narrower shape and don't like the protrusion, so I will sand them down to smooth out the transition from front to aft of the fuselage.
3. I also installed a solid block in the space under where the horizontal stab attached to the fuselage. This will make it a lot stronger.
4. Added the rear wingmount blocks. Still have to drill and tap the blocks.
5. I covered the horizontal stab with fabric.
ID:	1621516   Click image for larger version
ID:	1621517   Click image for larger version
ID:	1621518   Click image for larger version
ID:	1621519   Click image for larger version
ID:	1621520   Click image for larger version
