RCU Forums - View Single Post - Curare 60
Thread: Curare 60
Old 06-10-2011 | 03:23 PM
  #37
doxilia's Avatar
doxilia
Default RE: Curare 60
Tim,
I thought you had a laser incidence meter - but not yours, was confused.
If your FW is glued in then the old shim method works fine with the SIG beam mount you have used. Simple washers behind the beams do the trick - you might need one or two behind three screws depending on angle required.
David.
