[b][color=#0000FF][size=3][font="Tahoma"]Have put a couple of pilots in and a dash for each. Still trying to get the wing tube blocks done to locate the tube in the correct place but having trouble trying to drill the 17mm hole. Bought a 17mm drill and drilled one ok then next was larger. The drill bit is down slightly bent? may do 16mm hole and file out. Have cut out for the retracts and fitted the 4 wing servo covers. Been on hold as I put another tiger 60 in to the ground so need to finish regrouping with that first before this one goes much further. Also pulled my boomerang 60 out of retirement and making a tail drager out of it and putting the ASP 91FS. That way will have a spare if anything happens to my current Tiger 60. No 3 that is.
Hey Bob have you flown yours now. How did it go.
