RE: Good Second Plane
CG brought up a good point, I see way more Tigre series planes at the fields then I do any other. I have only built one 4* without clipping the wing but on the stock one the fellow didn't want anything more then a big floater. The same fellow has two of the small Space Walkers and I have flown the heck out of both of them. One is glow and he did one electric. Other then the sound {lack of} I can't tell the difference between the two when flying. It's also a plane you don't see a lot of. Once in a while a Super Sportster is seen at the field but not often. I can see the Pulse really well when in the air, love the covering job they used on it. It will fly pretty much the same as the 4* so the herd still has an almost 4* still in ARF form. The pulse also has some cool features I like a lot.
