RCU Forums - View Single Post - Sig 1/3 scale Spacewalker
Old 06-12-2011 | 11:48 AM
  #187
huck1199's Avatar
huck1199
Default RE: Sig 1/3 scale Spacewalker
Tom, thanks for the pics. I figured that was the way to go but was not sure how it looked, etc. I was going to sand down the point where the joint is on the side stringers so it is not so prominent. Your pic looks like you did the same. I was also thinking that I would add some vertical balsa filler at the the fuse joint for fabric attachment. This looks like a good place to seam the covering. Then I can cover the nose back to the end of the cockpit with one piece and cover the aft sections separately. How did you do your seaming?
ID:	1622290   Click image for larger version
