RE: Redcat Racing Tornado Thread
dont put a metal spur gear in... it will just transfer the stress to more expensive parts.. maybe your clutch bell is warped.. is the 47 tooth the big gear or the smaller of the two? i cant remember. it could be the area you run too. sand and little rocks are hard on spur gears. there is many things that can cause a spur gear to wear out, rocks, sand, bad gear mesh, warped gear, misalinged trannsmission or motor, or just alot of stress on it, like too much power or a really bad drag when turning the wheels.
