RE: got bit by a prop for the first time!
personally even if you can't post but link pictures I think you should. Really wakes you up and makes you think and hopefully it will not happen to you... or again. Mine also was a small electric with a reversed throttle servo situation and in grabbing for it as I've done a few times but this time reached into the prop arc and opened up the base of my hand 8 stitches worth at $100 per stitch ouch and ouch! So if you haven't been bit and it's still on here with all the pictures find and look at the thread and learn. If a prop is spinning or can, stay away from it or behind it and always think and don't get complacent. Seems like we all do and some with a lot worse outcome or more of a permanent one.
