RE: 60-90 Extra 260 and 300 DLE 20 Installation
Hello,
I am having an issue with the sensitivity of my DLE20 in my AeroWorks Extra 300 .60 - .90 ARF-QB. Would anybody be able to tell me if you have done anything different with the linkage from the servo to the carb? Longer arm? Throttle curve? I am using a HighTech 5945 for the throttle servo. I have tried it with the rod linkage on the servo arm closet in and also the 2nd closest in. The next I will try in the 3rd position out. The arm is the longer one on the DLS20 and is using the farthest out also.
It is too sensitive where when I give it just a little throttle it seems to rev the engine to what seems to be about 50% movement on the carb.
Thanks...
