RCU Forums - View Single Post - Tiny SC15 problem (Varying engine speeds)
Old 04-15-2002 | 09:34 AM
Flypaper 2
Default Tiny SC15 problem (Varying engine speeds)
As the engine unloads in the air more bubbles are formed causing the engine to slow down. Less bubbles when it slows down making it go richer causing it to rev up again, and so on. Bubbles are displacing fuel the engine cant get. Taboo. If it's only touching formers you might be able to grind out a bit. Goop also works good for an insulator.
