RE: AMR TRAINER 20
CanDo;
I like what you did on the wing; but with a 8+ lb airplane, I will be using metal bolts. As for the landing gear, the need to make the gear easy to ship doesn't carry much with me, a two piece gear will load up one side of the fuse if you happen to land funny. I think I will build a plate to carry across the gap. Did you have any fit issues with the dowel and the holes cut in the control surfaces?
L.
